в чем разница в мозгах?
пм7 и пп5?
![Изображение](http://maddix.users.photofile.ru/photo/maddix/95215194/xlarge/131157048.gif)
http://forum.pgmfi.org/viewtopic.php?f=40&t=3247
пишут что пп5 мозги с EDM ZC в частности с ровера
а вот тута - http://www.d-series.org/forums/naturall ... t-ecu.html пишут что:
Они все ОБД0 невтековые и взаимозаменяемы с пм6 и пм7.The PP5-E01 is a romless ecu which ran the early Rover 216 , 416 , GSi , Gti and possibly the 220 and 420, these early romless ECU's are mostly fitted to rovers without Lambda sensors. The early ecu's are difficult to chip and require some form of adapter like the romless PM6's and PM7's.
The alternatives are PP5-G01, PP4-R00 or PP4-G01 which I beleive to all be external ROM'd ecu's and common place in the UK. They are all ODB0 non Vtec ecu's, and should be swappable with PM7, PM6, etc. Some of these ECU's use an APS which may give CEL/Limp when not present.
PP5-E01 Rover 216 GTi (no lambda)
PP5-G01 Rover 216 GTi (with lambda), Honda Concerto 1.6 litre (Dohc) 93-96
PP4-G01 Rover 216 16V (with lambda), Honda Concerto 1.6 litre (Sohc) 92-96
PP4-R00 Rover 220 Coupe (with lambda), Honda Concerto 1.6 litre (Sohc) 93-96
PP5-R00 Honda Concerto 1.6 litre (Dohc) 93-96
